fatboyty175 Posted January 21, 2006 Report Share Posted January 21, 2006 hi everyone i can only get 1st and nuteral gear does anyone share this problem or anything simaller and does anyone know how to sort it out thanks in advance Quote Link to comment Share on other sites More sharing options...
cleanasawhistle Posted January 21, 2006 Report Share Posted January 21, 2006 Is iit juste me ore is the standhard of speling detiorioating in this modurn ayge ??!!!!! Quote Link to comment Share on other sites More sharing options...
-eddy- Posted January 21, 2006 Report Share Posted January 21, 2006 Not really helpful lol Maybe check,strip down the gearbox? if youve got a workshop manual then you will be able to find out how to do it in there Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted January 21, 2006 Report Share Posted January 21, 2006 My friend had one we took it out and could never get it out of 1st gear for some reason like it was stuck or there were no more gears to go in ? I thought maybe new plates ? Quote Link to comment Share on other sites More sharing options...
jackman Posted January 22, 2006 Report Share Posted January 22, 2006 New plates I'd say.. But I'm no pro. I think if it isn't shifting up into other gears, something is binding for sure. New plates, or another transmission I'd think Quote Link to comment Share on other sites More sharing options...
lukeo Posted January 22, 2006 Report Share Posted January 22, 2006 you should just buy my ty175 off me, runs like new, it looks good too. Quote Link to comment Share on other sites More sharing options...
james111089 Posted January 22, 2006 Report Share Posted January 22, 2006 new plates??? you dont need a clutch to change gear.......... Quote Link to comment Share on other sites More sharing options...
jackman Posted January 23, 2006 Report Share Posted January 23, 2006 Yeah but he can't get it into gear at all Quote Link to comment Share on other sites More sharing options...
kevin j Posted January 23, 2006 Report Share Posted January 23, 2006 If it won't shift with engine off, it's not your clutch. Pull the left cover off, and make sure the whole area is cleaned out. If nothing is binding the shifter, you'll need to pull the clutch side off fo check the finger that moves the shifter drum. If the spring breaks, it won't grab the shifter drum. Rotate the drum manually a bit at a time and see if the the transm works. Beyond that, you need a manual and some tools. k Quote Link to comment Share on other sites More sharing options...
