Beta Evo 300 2015 12v regulator
snorky29
Hi, any ideas would be a great help ....my 12v font lamp has stopped working (bulb is fine) i have measured the voltage across the switch and with a bit of throttle it maxes out at 5 volts ...is there a regulator tucked away somewhere i need to check
cheers Neil
I’m not sure about the 2015 but the earlier bikes powered the incandescent bulbs from the ac windings pre-regulator. The fan and, I believe, the microcontroller in the CDI ran off the 12V from the regulator. The new bikes with the LED bulbs run the lighting off the 12V from the regulator. Worth looking at the documentation on the Beta website.
