snorky29 Posted September 27, 2019 Report Share Posted September 27, 2019 Hi, any ideas would be a great help ....my 12v font lamp has stopped working (bulb is fine) i have measured the voltage across the switch and with a bit of throttle it maxes out at 5 volts ...is there a regulator tucked away somewhere i need to check cheers Neil Quote Link to comment Share on other sites More sharing options...
dan williams Posted September 28, 2019 Report Share Posted September 28, 2019 I’m not sure about the 2015 but the earlier bikes powered the incandescent bulbs from the ac windings pre-regulator. The fan and, I believe, the microcontroller in the CDI ran off the 12V from the regulator. The new bikes with the LED bulbs run the lighting off the 12V from the regulator. Worth looking at the documentation on the Beta website. Quote Link to comment Share on other sites More sharing options...
snorky29 Posted September 28, 2019 Author Report Share Posted September 28, 2019 Thanks Dan, Yes its 12-vac direct from the stater on tracing back i found poor connections (mucky corroded) at the ecu location, there are connections there regards Neil Quote Link to comment Share on other sites More sharing options...
