Sherco st 250 2018 gear selector
Carl Brown
Hi can anyone  help please  , Ive  got  a 2018 sherco st 250 and having trouble selecting second gear from 1st gear (it seams to find neutral) even after a positive click . Yet when staionary in gear and running its hard to find neutral . Confusing I know , but the bottom  line is it wont select neutral or second  when you need them . Does anyone  know what this could be ? Cheers .
If it's like my older Sherco, check that the shift return spring is not broken. The shift lever did not return to center on mine and made it difficult to shift up or down with my foot. I had to bring it back to the neutral position by hand most of the time. The spring seems to fracture and can look to be in good shape until it is removed. Then the fracture is visible. Sometimes they break and get into gears and such. I don't think I would leave it too long if this is the problem. Best of luck!
