Hard wired cooling fan 1996 jtr270.
Creepytheclutchmaster
Hi all I don't trust thermostats, so iv hard wired my fan on permanently on my 1996 jtr270, it works fine at idle and low revs with good air flow rate , but when you give  the motor a good rev up the fan slows almost to a stop, and then starts again as the revs come back down to idle. I'd would of thought the fan should spin faster with more revs??, but hay atleast it works lol. ? Any ideas?? Cheers
  On 10/9/2019 at 1:13 PM, scifi said:
Sounds as if the engine is trying to do the opposite of what you have done, and cancels out your polarity at higher revs...
Or did you just short circuit the thermostat..?
Expand
Yeah I just put the thermostat wires together, to mimic the activation of the thermostat when hot, I think it is the ac dc thing, maybe I need to change the position of the of the wires at the rectifyer,.
