trialsrydr Posted October 8, 2019 Report Share Posted October 8, 2019 Hello All, I have a new to me 2019 EVO 250. I need to remove the front headlight to fit a number plate. The problem is, when I disconnect the wiring to the light and ignition mode switch (also on the headlight mask) the cooling fan stops working. My question is; what is the fix for this? Thanks for any assistance. PS - I am no electrician so please be specific or post a photo - Thanks. Quote Link to comment Share on other sites More sharing options...
rcgods Posted October 8, 2019 Report Share Posted October 8, 2019 Removing the lights or the mapping switch should not stop the fan from running. Removing the mapping switch just leaves the bike in "summer" setting. I think you will need to go under the seat and check all the connections. It sounds like someone has been fiddling with the wiring. Quote Link to comment Share on other sites More sharing options...
technowaldo Posted October 8, 2019 Report Share Posted October 8, 2019 Lampkin’s sells a kit to do away with the headlight Quote Link to comment Share on other sites More sharing options...
rcgods Posted October 8, 2019 Report Share Posted October 8, 2019 1 hour ago, technowaldo said: Lampkin’s sells a kit to do away with the headlight That is essentially the same as removing the light and fitting a numberboard with 2 holes drilled in it to mount the cooling block. It sounds like there is some wiring issues Quote Link to comment Share on other sites More sharing options...
trialsrydr Posted October 8, 2019 Author Report Share Posted October 8, 2019 Thanks for the information so far. I have no idea what to look for, other than a disconnect. I will dig into it tomorrow. Anything else helpful would be greatly appreciated. PS - I put the headlight back on (after a big overheat) and then the fan worked. Quote Link to comment Share on other sites More sharing options...
reggie Posted October 8, 2019 Report Share Posted October 8, 2019 rcgods is correct. The item he/she referenced as the " cooling block " is the regulator / rectifier. This item is essential to having the cooling fan work. Quote Link to comment Share on other sites More sharing options...
stevec Posted August 24, 2020 Report Share Posted August 24, 2020 I just purchased a 2019 EVO 200. Can anyone verify whether the charging/ignition system is unique to the 200 2T? I ask because the voltage regulator is not located behind the headlight on mine. I've removed the headlight and the cooling fan still operates properly. Quote Link to comment Share on other sites More sharing options...
