nyawton Posted January 22, 2006 Report Share Posted January 22, 2006 Hi everyone, My sherco 290 has been sat idle for a few weeks now, as on my last ride i noticed oil spitting from the vent tube on the left hand side of the engine(not sure the name of this tube). I was advised that the problem is most likley the water pump seal/shaft have worn down letting all the radiator water into the bottom end and mix with the oil, causing it to come out of the vent tube. I am just wondering what are other peoples thoughts on this, it sounds good to me, but would just like to check before i try to fix this, Cheers Danny Quote Link to comment Share on other sites More sharing options...
nyawton Posted January 22, 2006 Author Report Share Posted January 22, 2006 Cheers i missed that service manual Just gota get off my lazy bum and give it a go now Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted January 23, 2006 Report Share Posted January 23, 2006 It's an easy fix. Quote Link to comment Share on other sites More sharing options...
nyawton Posted January 23, 2006 Author Report Share Posted January 23, 2006 yeah been looking at the service manual, on ryp. it looks ok to do, think i might give it a bash this weekend if i aint too hungover Quote Link to comment Share on other sites More sharing options...
shercosi Posted January 23, 2006 Report Share Posted January 23, 2006 my 290 does the samething peroidically !!check coolant level before taking the casings off!! mine does this if it hasnt been used for a while. I usually get enginge good and hot then drain oil and refill with new I personally think this is down to condensation in the engine cases, also do you power wash the bike alot cos this can force water past the engine seals. As I say check coolant level first!!!! Quote Link to comment Share on other sites More sharing options...
nyawton Posted January 23, 2006 Author Report Share Posted January 23, 2006 (edited) Will do, knowing me id take it apart to find there aint owt wrong yeah i power wash it after each ride, im always carefull around the exhaust, i do hope it is just condensation Cheers for the replys Edited January 23, 2006 by Nyawton Quote Link to comment Share on other sites More sharing options...
