Richard Thorne Posted November 5, 2019 Report Share Posted November 5, 2019 After getting spark sorted and donating lots of cash to the cause when i started up water was coming out the weep hole on the case where the water pump possibly is ? when reved comes out faster I did top rad up while had the tank off ..any help was looking forward to going out as not used for 12 months ... Quote Link to comment Share on other sites More sharing options...
jackman290 Posted November 5, 2019 Report Share Posted November 5, 2019 It sounds like you need a water pump seal. Hopefully the pump shaft is still in good shape and can be reused. Check Jim’s vid for some great info: 1:30 into it Quote Link to comment Share on other sites More sharing options...
Richard Thorne Posted November 5, 2019 Author Report Share Posted November 5, 2019 31 minutes ago, jackman290 said: It sounds like you need a water pump seal. Hopefully the pump shaft is still in good shape and can be reused. Check Jim’s vid for some great info: 1:30 into it Thankyou Jackman ? Quote Link to comment Share on other sites More sharing options...
