snorky29 Posted November 6, 2019 Report Share Posted November 6, 2019 can anyone help please, i cannot get the brake fluid to bleed through the from the master cylinder to the caliper , i have put a brand new seal kit in and everything is clean and tight , ive bled many hydraulic brakes in my time so not a novice ....but i cant fathom out what is wrong here, other than a possible score in the master cylinder ( which looks fine) is there a special technique that i need to know, the banjo fitting id higher than the fluid level so i cant see how gravity can help cheers Neil Quote Link to comment Share on other sites More sharing options...
Bilko Posted November 6, 2019 Report Share Posted November 6, 2019 Have you cracked the banjo nut open when trying to bleed the system i did on my Evo when i lost all my fluid.got my pressure back within minutes. Quote Link to comment Share on other sites More sharing options...
huski Posted November 7, 2019 Report Share Posted November 7, 2019 Back bleeding with a syringe on the bleed nipple generally works .Is there free play at the pedal to ensure the master cylinder piston is returning fully? Quote Link to comment Share on other sites More sharing options...
snorky29 Posted November 7, 2019 Author Report Share Posted November 7, 2019 thanks both for the info , but the issue is the stop nut on the brake pedal this dose not allow for full travel of the foot pedal when in its set position for riding , remove this nut and bolt and you get full travel of the piston thus pulling fluid through lovely , once bled put the stop nut and bolt back in the correct place for your travel liking and away to go cheers Neil Quote Link to comment Share on other sites More sharing options...
