2019 300 ST Sherco R16V rear shock adjustment
SeychellesSherco
I cannot find any literature on adjusting this shock. It has what I assume is a rebound ( or compression ) clicker on top. Anyone know which way turning it slows or speeds things up?
The standard black spring seems a bit soft for my 84 KG with not much bounce to get things hopping. Any suggestions on setting this puppy up properly.
The adjuster in this shock is a by pass on main valve. It act on both compression and rebound. But it has much more effect on rebound than compression.
Anyway it effect is limited for a small amount of oil passing by it small hole. So, again it effect is noticed only on small speed bumps.
Short answer: it is a rebound low speed adjuster.
