paul w Posted December 2, 2019 Report Share Posted December 2, 2019 Hi all, its been a while, but I'm returning again ! just looking for some advise - reviews on the 2018 4RT - it'll be my first 4 stroke, previously had Beta's Rev's and Evo 2t's Just don't want to make an expensive mistake ! thanks in advance Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted December 2, 2019 Report Share Posted December 2, 2019 Test ride first in case you don't like them. 1 1 Quote Link to comment Share on other sites More sharing options...
jimmyl Posted December 2, 2019 Report Share Posted December 2, 2019 There are some very good deals on std 260 4rts . The bike is basically the same from 16 on. You get Honda build quality and the option to upgrade some parts later on if you feel the need - rear shock and an s3 front pipe are good additions - the pipe more than shocker for the more clubman rider . all 4rts ride similar - the 300rr better and 301 better again but you pay for the improvement if you ride a more traditional style then 4rt suits - if you are a rev and dump the clutch then maybe not so. either way the smile factor of a 4rt on a bit of a blast is unique?? 1 1 Quote Link to comment Share on other sites More sharing options...
jimmyl Posted December 2, 2019 Report Share Posted December 2, 2019 If you switch to the 4rt see if mr Sumter will give you some tips being in his neck of the woods - nobody better to learn off ?? Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted December 4, 2019 Report Share Posted December 4, 2019 The 2018 standard 4RT should be a great bike, nearly identical to the 2017 I had a chance to ride. The two in our group are fantastic bikes and I wouldn't hesitate to get a 2018 260. If you do get it I hope you like it a lot! Good luck making your call. Quote Link to comment Share on other sites More sharing options...
