Evo 300 2012 fork seal and bushes dimensions
pindie
As it says. I’d like to strip and rebuild my forks and fit new SKF seals. Rather than strip everything and then order once measured can someone let me know the dimensions of the parts?
 I will be ordering from a supplier who doesn’t do bike model specifically but can match up dimensions no problem.
thanks in advance.
thanks in advance.
There is a difference between rotary seals and hydraulic type. Rotary will wear very fast.
The two Inner brass bushings may need replacing as well, those will have to be ordered from Beta or you can use the Jitsie ones, there cheaper but need just a touch of filling to make them fit perfect.   Jitsie part # Jl118-tcs 01.004 Top bushing and Ji118-tcs 01.003 inner bottom. You'll find out for sure when you take them apart.
