suzuki250 Posted December 5, 2019 Report Share Posted December 5, 2019 I recently changed the seals on txt pro but the od of the seals supplied are undersize. They seemed to fit ok The od should have been 52.2mm but the ones supplied are 52.0mm, they don’t seem to be leaking but I’ve not done a trial yet! Anyone else had this issue, I don’t fancy wasting the oil to change them Quote Link to comment Share on other sites More sharing options...
huski Posted December 6, 2019 Report Share Posted December 6, 2019 Don't think I would have fitted them .Id change them for the correct ones in case they start leaking at an event and contaminate the brake pads as well.Id get the new seals from a different source too Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted December 6, 2019 Author Report Share Posted December 6, 2019 (edited) I wouldn't have fitted them normally, I just presumed they were correct. It was only after I looked at the old ones I noticed the size difference ? Edited December 6, 2019 by suzuki250 Quote Link to comment Share on other sites More sharing options...
huski Posted December 6, 2019 Report Share Posted December 6, 2019 Annoying,some of the crap stuff that's out there.Means doing the job twice through no fault of your own Quote Link to comment Share on other sites More sharing options...
twinshockdude Posted December 6, 2019 Report Share Posted December 6, 2019 0.2mm = 0.008" dont worry about it ! 1 Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted December 7, 2019 Author Report Share Posted December 7, 2019 22 hours ago, twinshockdude said: 0.2mm = 0.008" dont worry about it ! Very True the only way to find out is to do a trial 1 Quote Link to comment Share on other sites More sharing options...
