fatboyty175 Posted January 23, 2006 Report Share Posted January 23, 2006 hi someone said strip the gearbox on my old ty175 but how do i do this because the nut wont crack on the clutch plate holder because ive got nothing to hold the friction plate holder wuith thanks in advance Quote Link to comment Share on other sites More sharing options...
landrover Posted January 24, 2006 Report Share Posted January 24, 2006 you will need a clutch holding tool,not very expensive available from most bike shops,also check the return spring on the selecter to see if it's broke,i had a bike that would not engage gears and that was the problem.where are you located, we have a holding tool Quote Link to comment Share on other sites More sharing options...
