rob77 Posted December 24, 2019 Report Share Posted December 24, 2019 Morning all. Embarrassing confession on this one...for some reason I used mineral clutch fluid when I was bleeding my brake systems a couple of weeks ago. Life has since got in the way and I only got back in the garage yesterday to put dot4 through. However now there is absolutely no pressure in my front system. Do I just need to persist/get a syringe on it, or will the mineral fluid have damaged any of the components? Cheers Rob 1 Quote Link to comment Share on other sites More sharing options...
Bm1200 Posted December 24, 2019 Report Share Posted December 24, 2019 Sadly all the seals will need changing as they will have swollen and eventually split, might be ok with the pipe but it will need to be flushed. lots have people have made the mistake the other way by putting Dot 4 in mineral clutches.That generally works for a week before the seals swell up and split. BMW motorcycle forums are full of tales with bikes from about 2010. This mistake is less common because not so many people have mineral oil in their garage to make the mistake. I have first hand experience because my Nephew was sold Mineral oil to go into a Peugeot braking/Clutch system that should use DOT 4. First the clutch went light then stopped lifting fortunately it made it undriveable before it stopped the brakes working. The cost was enough to scrap the car. Nige 2 Quote Link to comment Share on other sites More sharing options...
rob77 Posted January 1, 2020 Author Report Share Posted January 1, 2020 Thanks for the reply Nige. Will this include piston seals as well as master cylinder seals? Quote Link to comment Share on other sites More sharing options...
thall1 Posted January 1, 2020 Report Share Posted January 1, 2020 The front calliper pistons seals aren't immersed in fluid but it may be wise to change them... you can’t buy just the seals... it’s a new piston and seal set...the seals are ‘square’ in form but I have in the past used ‘O’ rings that work fine with new pads but as the pads wear the o rings don’t allow the pistons to creep out to take up wear in the pads. 1 Quote Link to comment Share on other sites More sharing options...
