markbxr400 Posted January 9, 2020 Report Share Posted January 9, 2020 Tweaked my exhaust in a loop out. Have been trying to locate an OEM one but seems that the US has been/is on an extended backorder. Anyone happen to know where I might find one? Thanks in advance. Mark Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted January 9, 2020 Report Share Posted January 9, 2020 (edited) 1 hour ago, markbxr400 said: Tweaked my exhaust in a loop out. Have been trying to locate an OEM one but seems that the US has been/is on an extended backorder. Anyone happen to know where I might find one? Thanks in advance. Mark Have you talked to Dennis at https://www.overlandtrail.biz/? If you have and he doesn't have one you might consider a Mitani? He should be able to get you one and I also see that jbanyers looks like they have one as well. https://jbanyeres.com/en/exhaust-pipe/4271-escape-mitani-completo-especial-para-montesa-cota-300rr-titanio-y-carbono-diametro-28mm.html?search_query=Exhaust&results=73 Edited January 9, 2020 by jonnyc21 Quote Link to comment Share on other sites More sharing options...
markbxr400 Posted January 9, 2020 Author Report Share Posted January 9, 2020 8 hours ago, jonnyc21 said: Have you talked to Dennis at https://www.overlandtrail.biz/? If you have and he doesn't have one you might consider a Mitani? He should be able to get you one and I also see that jbanyers looks like they have one as well. https://jbanyeres.com/en/exhaust-pipe/4271-escape-mitani-completo-especial-para-montesa-cota-300rr-titanio-y-carbono-diametro-28mm.html?search_query=Exhaust&results=73 Thanks Jonny. Yeah, had tried them. They didn't stock and would have to try and order like everyone else. On the Mitani, $$ OUCH !! May have to either try and find someone that did a swap for aftermarket and see if they'd sell me their OEM, or pull the rivets and take a hammer to mine to try to straighten it out. Not quite sure how the exhaust was able to bend like this on a 0 mph loop out. End was full of dirt. Trying to re-enact, I can't get the exhaust tip to get into the dirt. Thanks again. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted January 9, 2020 Report Share Posted January 9, 2020 I think that’s the full exhaust and I believe you can get just the can, but even that will likely be a bit of $. Good luck getting your bike sorted! 1 Quote Link to comment Share on other sites More sharing options...
