300RR/4RT Exhaust
markbxr400
1 hour ago, markbxr400 said:
Tweaked my exhaust in a loop out.  Have been trying to locate an OEM one but seems that the US has been/is on an extended backorder.  Anyone happen to know where I might find one?
Thanks in advance.
Mark
Have you talked to Dennis at https://www.overlandtrail.biz/
If you have and he doesn't have one you might consider a Mitani?  He should be able to get you one and I also see that jbanyers looks like they have one as well.
https://jbanyeres.com/en/exhaust-pipe/4271-escape-mitani-completo-especial-para-montesa-cota-300rr-titanio-y-carbono-diametro-28mm.html?search_query=Exhaust&results=73
Edited by jonnyc21
Thanks Jonny.  Yeah, had tried them.  They didn't stock and would have to try and order like everyone else.  On the Mitani, $$ OUCH !!
May have to either try and find someone that did a swap for aftermarket and see if they'd sell me their OEM, or pull the rivets and take a hammer to mine to try to straighten it out.
Not quite sure how the exhaust was able to bend like this on a 0 mph loop out.  End was full of dirt.  Trying to re-enact, I can't get the exhaust tip to get into the dirt.
Thanks again.
