Betaireland Posted January 11, 2020 Report Share Posted January 11, 2020 This evening I noticed the gear oil was very white looking as if water was in the oil on me beta so I drained it and put fresh oil in any one shed some light on this cheers Quote Link to comment Share on other sites More sharing options...
feetupfun Posted January 11, 2020 Report Share Posted January 11, 2020 If you haven't just been riding in deep water then you probably have a leaking water pump shaft seal or a corrosion hole in the water pump housing 1 Quote Link to comment Share on other sites More sharing options...
Betaireland Posted January 11, 2020 Author Report Share Posted January 11, 2020 Cheers for the reply I havnt being riding in deep water I suspected it was going to be the waterpump seal Is it much of a job to replace I will strip it down tomorow evening Quote Link to comment Share on other sites More sharing options...
feetupfun Posted January 12, 2020 Report Share Posted January 12, 2020 Small job either way but expensive if it's a hole in the casing 1 Quote Link to comment Share on other sites More sharing options...
Betaireland Posted January 13, 2020 Author Report Share Posted January 13, 2020 Was out yesterday at a practice day checked the oil throughout the day and was not milly or discoloured Quote Link to comment Share on other sites More sharing options...
