rusty ken Posted January 17, 2020 Report Share Posted January 17, 2020 Hi folks, Does anyone know if there a source for new crankshafts for Villiers 9e or 32a engines? I'm looking to convert an 11e engine, which has the extra bearing on the right hand side and the longer crankshaft. The plan is to remove the additional bearing (and casing) and to fit the narrower crank. I had seen full circle crankshafts for sale on-line, but they now appear to be out of stock. I'm happy to consider fitting a hammer head crank, but the trend (and the maths) would suggest moving to the full circle version if it were available. Alternatively, is there a modern 2-stroke crank that can be modified to fit the Villiers cases? Before anyone screams about using modern internals in a pre '65 bike, this will be ridden in local novice and sportsman events where everyone else will be riding mono shocks. Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted January 17, 2020 Report Share Posted January 17, 2020 (edited) 2 hours ago, rusty ken said: Hi folks, Does anyone know if there a source for new crankshafts for Villiers 9e or 32a engines? I'm looking to convert an 11e engine, which has the extra bearing on the right hand side and the longer crankshaft. The plan is to remove the additional bearing (and casing) and to fit the narrower crank. I had seen full circle crankshafts for sale on-line, but they now appear to be out of stock. I'm happy to consider fitting a hammer head crank, but the trend (and the maths) would suggest moving to the full circle version if it were available. Alternatively, is there a modern 2-stroke crank that can be modified to fit the Villiers cases? Before anyone screams about using modern internals in a pre '65 bike, this will be ridden in local novice and sportsman events where everyone else will be riding mono shocks. https://villiersservices.co.uk/ or http://www.nortonvilliers.com/ or http://www.alpha-bearings.com/ Any of the above may be able to help Edited January 17, 2020 by trialsrfun Quote Link to comment Share on other sites More sharing options...
