rsvrt9
rsvrt9
Try the obvious things first. Strip each connecter clean and ensure each one is tight. Disconnect the kill switch. Check the earths including the stator to the engine. Make sure the flywheel woodruff key is present and correct (if the timing is too far out it won't spark. Substitution with known components from another bike follows if you are lucky enough to find one. Rex Caunt or electrex world may be able to help, depending if they think there is enough interest in doing a system for that bike. If all else fails modify a pit bike system to fit
  • Thanks 1
