montesa315 Posted January 24, 2006 Report Share Posted January 24, 2006 hi. i am new to this forum malarky so please bear with me. i am posting this for my brother as he has no access to the internet. we have just rebuilt his 1995 jt350 with a new piston and rings ect. now there is a quite bad pinking problem that definatly wasn't there before. we have rung up biketec and they said something about using 2 base gaskets has anyone out there ever heard of this as he is afraid to ride it incase it all melts. cheers. Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted January 24, 2006 Report Share Posted January 24, 2006 I can see your new to the forum look how many posts you made Quote Link to comment Share on other sites More sharing options...
montesa315 Posted January 24, 2006 Author Report Share Posted January 24, 2006 yeah. sorry bout that. had a dim moment, or 8??!!!! Quote Link to comment Share on other sites More sharing options...
husky Posted January 24, 2006 Report Share Posted January 24, 2006 try running it on shell optimax at 80/1 mix with a good synthetic 2 stroke oil.Check the carb settings/jets are correct,GasGas uk should be able to tell you what they should be,they're very helpful.Sometimes retarding the ignition timing stops it pinking but it loses top-end power/revs.Went thro all this on a 95 350 I had after someone played about with it,and an extra .5 mm base gasket sorted it,it. also made it easier to startHope this helps,if you're in any doubt post your phone no. and i'll speak to you.Good luck Quote Link to comment Share on other sites More sharing options...
montesa315 Posted January 24, 2006 Author Report Share Posted January 24, 2006 thanks for that husky. i will try that extra base gasket this weekend as i cant see it being the timing as we haven't touched any settings on the bike at all. we are running in optimax at the moment with castrol tt oil which i've never had any problems with. i'll let you know how i get on. Quote Link to comment Share on other sites More sharing options...
husky Posted January 24, 2006 Report Share Posted January 24, 2006 good luck,but bear in mind that someone else may have played with it before you Quote Link to comment Share on other sites More sharing options...
montesa315 Posted January 26, 2006 Author Report Share Posted January 26, 2006 that extra base gasket really did the trick. not a hint of pinking even on normal shi**y unleaded. sorted! now, off for a pint Quote Link to comment Share on other sites More sharing options...
husky Posted January 26, 2006 Report Share Posted January 26, 2006 the definetive method of ending maintenance,have several pints. Quote Link to comment Share on other sites More sharing options...
magicmat Posted January 27, 2006 Report Share Posted January 27, 2006 im rebuilding a 1993 250 engine, should i use two base gaskets to make sure this problem doesnt develop ? or just wait and see?? How could you tell? the engine encredibly hot? or is it about staying hot after you've killed the engine?? Cheers Quote Link to comment Share on other sites More sharing options...
gasgas350 Posted June 27, 2010 Report Share Posted June 27, 2010 hi. i am new to this forum malarky so please bear with me. i am posting this for my brother as he has no access to the internet. we have just rebuilt his 1995 jt350 with a new piston and rings ect. now there is a quite bad pinking problem that definatly wasn't there before. we have rung up biketec and they said something about using 2 base gaskets has anyone out there ever heard of this as he is afraid to ride it incase it all melts. cheers. hi m8 im currently in the same process could you give me the price of the gasket kit you got and the contact num of biketec this would be a big help cheers gas gas 350 Quote Link to comment Share on other sites More sharing options...
