montesa pierre Posted January 25, 2020 Report Share Posted January 25, 2020 Can I fit a counter balance weight from a 349 onto a 248 Crankshaft. The 248 has a part no 5160 171 02, whilst the 349 part no is 5160 171 03 Failing the conversion can anybody suggest where I can obtain a new or second hand 248 counter balance weight. Thank you. Quote Link to comment Share on other sites More sharing options...
barnesy Posted January 27, 2020 Report Share Posted January 27, 2020 I think the 248 and 349 engines are the same apart from the bore so you should be able to fit it. As an aside I turned down the counterweight on my 348 a bit to put less stress on the crank and get a better engine response. Quote Link to comment Share on other sites More sharing options...
