t-shock 250 Posted February 11, 2020 Report Share Posted February 11, 2020 You'll need to change oil during a trial at that rate!! Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 11, 2020 Report Share Posted February 11, 2020 38 minutes ago, txt joker said: Canny answer that,I’m sure I read in another post in one of these forums to do it that regular Changing oil is never a bad thing, but atf is designed to run for thousands of miles. Quote Link to comment Share on other sites More sharing options...
txt joker Posted February 11, 2020 Author Report Share Posted February 11, 2020 1 hour ago, t-shock 250 said: You'll need to change oil during a trial at that rate!! I now think it was something to do with the clutch dragging if you changed it more regular it helped Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted February 12, 2020 Report Share Posted February 12, 2020 17 hours ago, txt joker said: I now think it was something to do with the clutch dragging if you changed it more regular it helped I change mine every 6 months (if I remember) never had a problem with clutch drag Quote Link to comment Share on other sites More sharing options...
guy53 Posted February 12, 2020 Report Share Posted February 12, 2020 Having both type ( modern and twinshock bike ) I can tell you that the oil change is much less frequent on the TS than the modern. Guy Quote Link to comment Share on other sites More sharing options...
