Spanky Posted February 8, 2020 Report Share Posted February 8, 2020 Bike running very hot. Magneto and clutch casings are also very hot to the touch. Checked coolant, all ok. Fan is cutting in and out (though more often than it used to. Plug colour is fine. New plug in. Bike runs fine from cold, after about 10 minutes casings are very hot to the touch as is the exhaust silencer. Carb has been apart and is clean, standard settings other than needle lifted 1 notch. Bike also seems to not want to rev as it used to. Anybody got any ideas? ?? Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 8, 2020 Report Share Posted February 8, 2020 (edited) Check timing. (Or don't check it, hard trying to help people sometimes.) Edited February 8, 2020 by b40rt Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 8, 2020 Report Share Posted February 8, 2020 I would be checking the lmpellor. 1 Quote Link to comment Share on other sites More sharing options...
Spanky Posted February 8, 2020 Author Report Share Posted February 8, 2020 27 minutes ago, lineaway said: I would be checking the lmpellor. ?, will do, but I dont think the casings would get that hot. think it would boil over first. Quote Link to comment Share on other sites More sharing options...
gasserguy Posted February 8, 2020 Report Share Posted February 8, 2020 Phone Steve Saunders. 1 Quote Link to comment Share on other sites More sharing options...
pauls320 Posted February 8, 2020 Report Share Posted February 8, 2020 Might want to look at the CDI unit, sounds like a few owners have been having issues with them Quote Link to comment Share on other sites More sharing options...
Spanky Posted February 8, 2020 Author Report Share Posted February 8, 2020 6 hours ago, b40rt said: Check timing. (Or don't check it, hard trying to help people sometimes.) Sorry dude, wasn't trying to be rude. I didn't answer as i dont know how timing could change other than woodruff key going. The bike runs perfectly when cold. Quote Link to comment Share on other sites More sharing options...
Spanky Posted February 8, 2020 Author Report Share Posted February 8, 2020 2 hours ago, pauls320 said: Might want to look at the CDI unit, sounds like a few owners have been having issues with them So I've heard. Will do. Thanks. Quote Link to comment Share on other sites More sharing options...
huski Posted February 8, 2020 Report Share Posted February 8, 2020 Sounds like the ignition isn't advancing with revs as it should,which I think points to a duff cdi.Worth speaking to Steve Saunders before you get your wallet out.Do you know anyone with the same bike you try the CDI from Quote Link to comment Share on other sites More sharing options...
leembarnes Posted February 8, 2020 Report Share Posted February 8, 2020 Cdi....I'm on my third one now. When mine went symptoms were different each time Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 8, 2020 Report Share Posted February 8, 2020 2 hours ago, Spanky said: Sorry dude, wasn't trying to be rude. I didn't answer as i dont know how timing could change other than woodruff key going. The bike runs perfectly when cold. No problem, but faulty cdi may effect your timing causing overheating. Impeller is also worth checking as said above. Quote Link to comment Share on other sites More sharing options...
anachronism Posted February 9, 2020 Report Share Posted February 9, 2020 (edited) 17 hours ago, leembarnes said: Cdi....I'm on my third one now. When mine went symptoms were different each time @leembarnes: Did you change out the CDI(s) yourself & if so, how difficult was it? Edited February 9, 2020 by anachronism Quote Link to comment Share on other sites More sharing options...
leembarnes Posted February 9, 2020 Report Share Posted February 9, 2020 20 hours ago, anachronism said: @leembarnes: Did you change out the CDI(s) yourself & if so, how difficult was it? It's easy enough to do just a little fiddly. Cdi sits under the frame behind the headstock, remove tank and you can see and feel it. It's held onto a bracket with a Velcro elasticated strap. I remove that first and gently pull cdi backwards, remove from plug and replace. Note any moisture or rust on the pins in the cdi. Mine has been clean and dry both times to be fair but still I don't take the jet wash any where near it. Quote Link to comment Share on other sites More sharing options...
Spanky Posted February 12, 2020 Author Report Share Posted February 12, 2020 Update: Fault confirmed as failing cdi unit. Bike now running sweet again. ? Thanks to all that offered advice/tried to help. 2 Quote Link to comment Share on other sites More sharing options...
