Spanky Posted February 12, 2020 Report Share Posted February 12, 2020 Following on from my sick trs thread, whilst investigating the problem I found a couple of connectors where I could see moisture had gotten in. What is the best method for keeping water out of these connectors? I've heard of people using vaseline and dielectric grease. Quote Link to comment Share on other sites More sharing options...
ChrisCH Posted February 12, 2020 Report Share Posted February 12, 2020 There are some good spray products about like X20 that work for long enough to do a trial. If you want to waterproof things where it is possible to do so a shrink wrap is the best way to go. Quote Link to comment Share on other sites More sharing options...
Spanky Posted February 12, 2020 Author Report Share Posted February 12, 2020 1 hour ago, ChrisCH said: There are some good spray products about like X20 that work for long enough to do a trial. If you want to waterproof things where it is possible to do so a shrink wrap is the best way to go. Cheers Chris, I haven't had a problem getting through a trial it's more to do with ensuring moisture doesnt get through to the pins of the plugs on things like the cdi and sit there coroding the pins Quote Link to comment Share on other sites More sharing options...
al_orange Posted February 12, 2020 Report Share Posted February 12, 2020 4 hours ago, Spanky said: Cheers Chris, I haven't had a problem getting through a trial it's more to do with ensuring moisture doesnt get through to the pins of the plugs on things like the cdi and sit there coroding the pins That's exactly what dielectric grease is for. I think I'll be checking mine connections and greasing them soon. Quote Link to comment Share on other sites More sharing options...
