Midlife Montesa Posted February 13, 2020 Report Share Posted February 13, 2020 Hi all, I'm after advice, I have recently purchased a new trials bike. (Montesa Cota). I am after as much information as possible. I haven't ridden or owned a bike for over 20 years.. I'm 52 years old and my old bike was a montesa that I used to just have fun times on.. I never competed just rode with few friends on weekend.. after feeling I want to ride again.. I want to know what is the standard format after use to keep my new bike in great condition.. like cleaning lubricating all the important parts and with what products to use.. Any information will be beneficial as I'm not very mechanical, Thanks in advance. 2 Quote Link to comment Share on other sites More sharing options...
sherco70 Posted February 13, 2020 Report Share Posted February 13, 2020 Be careful using a pressure washer as it can blow water past seals, and electrical connections. And follow the recommendations for care. Art 1 Quote Link to comment Share on other sites More sharing options...
Midlife Montesa Posted February 13, 2020 Author Report Share Posted February 13, 2020 Thanks very much, is there any types of spray to use after hose pipe wash.. and what are the essential parts to regularly lubricate etc etc.. Quote Link to comment Share on other sites More sharing options...
technowaldo Posted February 14, 2020 Report Share Posted February 14, 2020 Jet wash it ,let it dry a bit and cover the whole bike in rhino shine Quote Link to comment Share on other sites More sharing options...
jimmyl Posted February 14, 2020 Report Share Posted February 14, 2020 I wash off with suitable spray on cleaner - then start bike and let in warm up. While warming up I spray with wd40 - the non aerosol type - spray chain etc water should run if or evaporate . I then wipe over with an old towel to remove water and excess wd40 ( other brands available) . Then quick wizz up and down the drive apply brakes to generate some heat to dry of brakes . cover with a blanket ready for following weekend Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted February 14, 2020 Report Share Posted February 14, 2020 (edited) You can use Muc-off or similar to spray on prior to cleaning, get yourself some dishwashing brushes as well, ideal for poking into places to clean where you can't get your hands , ( oooh Matron) and a lot of these cleaning product people make aftercare sprays as well, if you want. i agree with Jimmyl, WD40 sprayed on and wiped in is ideal. Edited February 14, 2020 by jonboy883 1 Quote Link to comment Share on other sites More sharing options...
Midlife Montesa Posted February 14, 2020 Author Report Share Posted February 14, 2020 On 2/14/2020 at 3:34 AM, technowaldo said: Jet wash it ,let it dry a bit and cover the whole bike in rhino shine Expand Thanks for information.. Quote Link to comment Share on other sites More sharing options...
Midlife Montesa Posted February 14, 2020 Author Report Share Posted February 14, 2020 On 2/14/2020 at 6:44 AM, jimmyl said: I wash off with suitable spray on cleaner - then start bike and let in warm up. While warming up I spray with wd40 - the non aerosol type - spray chain etc water should run if or evaporate . I then wipe over with an old towel to remove water and excess wd40 ( other brands available) . Then quick wizz up and down the drive apply brakes to generate some heat to dry of brakes . cover with a blanket ready for following weekend Expand Thanks for your time regarding information, I feel all the replies are very valuable. I just need alot of practice I guess to be able to ride it now..!! Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted February 14, 2020 Report Share Posted February 14, 2020 (edited) I would suggest you clean the air filter every outing as the 4RT seems to collect a lot of dirt. It's easier if you use two and swap them. I recommend NoToil filter oil as it washes out with washing powder, no need to use petrol. Coat the walls of the airbox with grease in order to catch any bits that get by the filter. Basically you want to lubricate any point of movement, especially the rear linkage which will require a regular stripdown. I also recommend you grease every thread you can get to now, before they sieze up to make future work easier. I use whatever good quality 10/40 is on sale for the motor (it's always been Castrol Power 4T so far) and have settled on Rock Oil Lite for the gearbox but it won't take you much searching on here to see that there is a wide range of preference on that subject. It may already exist but some old hand should do a Youtube video on the correct preparation and maintenance of a trials bike, using experience to show the "wrinkles" as they used to be called. Ah yes, tyre presssures. Six front, four rear is a good starting point but local riders will best advise to suit the going. I'm sure the 4RT starting technique was explained to you. Edited February 14, 2020 by 2stroke4stroke 3 Quote Link to comment Share on other sites More sharing options...
johnnyboxer Posted February 14, 2020 Report Share Posted February 14, 2020 ELF HTX740 in the GearBox 2 Quote Link to comment Share on other sites More sharing options...
huski Posted February 14, 2020 Report Share Posted February 14, 2020 Make sure you don't get wd40 on the brakes.Clean air filter and clean oil,it'll go forever in clubman hands. 1 Quote Link to comment Share on other sites More sharing options...
rr62 Posted February 14, 2020 Report Share Posted February 14, 2020 Welcome to the clan - nothing to add to the above good advice except I have found that a silicon furniture polish seems to give a good shine and protect the plastics. 2 Quote Link to comment Share on other sites More sharing options...
jimmyl Posted February 14, 2020 Report Share Posted February 14, 2020 (edited) Several air filters is a must. Don’t oil filter then put straight into bike as will be a pig to start - oil and leave to stand while you do the other stuff. i always drop the pads out and clean inside callipers and give the pads a quick deglaze with a bit of sandpaper laid flat on the bench. get some mesh and hot glue inside the mudguard to cover the vents - keeps loads of muck and water out. you can also run a bead of silicon on little mudguard extension to seal gap to mudguard Edited February 16, 2020 by jimmyl 1 Quote Link to comment Share on other sites More sharing options...
section swept Posted February 14, 2020 Report Share Posted February 14, 2020 (edited) First off, plug the exhaust and block off the air box entry. Rather than a pressure washer, a garden hose on domestic water pressure will get most of the large crud off....if you do not let it dry out i.e. harden. Thats what happens when you throw the bike in the garage/shed and bugger off down the pub??! Back to cleaning, after you have hosed as much crap off as is reasonably possible, make up a mix of wash and wax 50/50 in a sprayer and liberally spray everywhere....thats on the bike! Leave for 3/4 minutes and then with a softish brush clean the wheel rims and hubs. Take care near any oil seals on any area of the bike as you can force dirt into the seals.....not good. Sponge to clean the plastics with lots of water and wash and wax (from a bucket) wash the bars snd controls. Tyres may need a scrub with a stiff brush, use a separate stiff brush for the chain. Don’t forget to clean under the mudguards....! Now hose off the whole bike and with a critical eye check for stowaways....lumps of crap still clinging on?....Happy....now if you have a compressor do not go mad and blast the water off, this will just drive moisture into all of the places you don't want it, use compressed air from a distance to the bike so it acts more like a drying draft like the wind. Use an absorbent cloth such as a soft bath towel....use the other half's if you have no old towels....micro fibre cloths are excellent for mopping up water and polishing....WD40 is an excellent product but it is also quite good at softening sticker adhesive, I prefer to use Silicon as a dressing for most parts of the bike. Obviously not any where on the brake surfaces. Now check you have not forced any water into the air box or exhaust, remove blocking plugs etc and air box drain caps to ensure no water is lurking about in the bottom of the air box. Gently operate the kick start to ease the piston over TDC. Make sure you have not dislodged the plug cap and try to start the engine. If it wont start as is usual for your bike, stop kicking and check fuel amount, kill switch in operate position, spare plug put into HT plug cap and swift kick to establish good spark or not, WD40 sprayed onto spark plug ( the one in the engine) and inside cap and refit.....try engine again...you may well need choke, don't forget the engine will have been chilled right down with all the cold water. If it still will not start, its something you have done will cleaning or introduced by way of water deluge. If it starts, shut the engine down, any residual heat will only cause condensation in the cylinder and exhaust. Don’t wash your bike, car, van etc with warm or hot water, this reactivates any salts or chemicals and the hot water carries the residue into all of the crevices and ledges ...not good. Use wash and wax as this helps hold back corrosion and gives a shine to smooth surfaces. There you go all done, nice and clean ready to go into sleep mode until the next time. With the exhaust cold a spray of WD40 ( other products are available) onto the front pipe and silencer system will help prevent rusting/staining. Silicon spray on the rims, hubs, bars and plastics will help stop the next lot of mud etc from getting a hold when you next ride. Some old stagers wipe the frame and rims over with a rag lightly soaked in engine oil, gives a nice shine and leaves scratches to frames as scratches not rust areas. Happy cleaning.......I ‘ll be waiting for the “ah but.....” comments?? Edited February 14, 2020 by section swept Quote Link to comment Share on other sites More sharing options...
Midlife Montesa Posted February 14, 2020 Author Report Share Posted February 14, 2020 On 2/14/2020 at 9:02 AM, 2stroke4stroke said: I would suggest you clean the air filter every outing as the 4RT seems to collect a lot of dirt. It's easier if you use two and swap them. I recommend NoToil filter oil as it washes out with washing powder, no need to use petrol. Coat the walls of the airbox with grease in order to catch any bits that get by the filter. Basically you want to lubricate any point of movement, especially the rear linkage which will require a regular stripdown. I also recommend you grease every thread you can get to now, before they sieze up to make future work easier. I use whatever good quality 10/40 is on sale for the motor (it's always been Castrol Power 4T so far) and have settled on Rock Oil Lite for the gearbox but it won't take you much searching on here to see that there is a wide range of preference on that subject. It may already exist but some old hand should do a Youtube video on the correct preparation and maintenance of a trials bike, using experience to show the "wrinkles" as they used to be called. Ah yes, tyre presssures. Six front, four rear is a good starting point but local riders will best advise to suit the going. I'm sure the 4RT starting technique was explained to you. Expand Thanks for taking the time to post this valuable information.. I'm not mechanically minded but if it means looking after my new bike, I'm sure il learn very quickly.. thanks again Quote Link to comment Share on other sites More sharing options...
