Gas gas 2006 280txt sight glass white?
David.. Argyll
You can get a water pump repair kit from your local GG dealer or, for more money a complete water pump. Drain the oil as soon as you can, it has mixed with water, the water causes the fibres on the clutch plates to swell creating more problems for you. Perhaps flush out the residual oil with 400ml of ATF rated to Dexron III then dump that and refill again with the same oil and quantity. Other riders use different types of oil but, ATF Dex III has been fine for all my bikes for over 25 years, and it's not expensive! Bye, Peter B.
