interchangable parts between TYmono and TYZ 250's
Twinshockandy
Front wheel spindle
Front wheel (Pinky)
Front brake (Pinky)
Forks and yokes sort of interchangeable but need to change the stem to a TY Mono one as the forks are larger diameter
Air Filter
Probably some other odds and ends too.  Mudguard and mudguard brace are different on the TYZ as the forks are different.
  • Thanks 1
Kictstarts & gear levers
Front master cylinder and throttle
Clutch perch
Levers
Speedo, cable and drive
Lights
Air filter cage and strap, foam filter
Petrol cap
Rear swingarm rear sprocket plastic guard
are interchangeable
Maybe Alloy TYZ swingarm, with some mods, possibly shock too, with mods
Edited by johnnyboxer
  • Thanks 1
So, completely different bottom end?
Clutch plates?
I was always under the impression the TYZ was pretty much a water cooled top end on a TY Mono bottom end.
Even the side cases look similar-ish....
Then again, i've never seen one in the flesh nor had a motor on the bench....
Clutch plates?
Was wondering that, myself, hence asking the question...............certainly generator cover looks (and here I'm  like thai-ty having never seen a TYZ in the flesh) he same,
Also was interested that the monoshock unit wouldn't fit, but looking at the swing arm unit on a TYZ (via good ol ebay) I can see they are different.
Again hanks to all who've replied
Andy
The TY250Z motor is based on an early 1990s YZ250 motor. The TY250 air cooled mono motor is based on an early 1980s YZ250 motor.
They started with a clean sheet of paper for the TY250Z but did use the pinky front wheel.
  • Thanks 1
  • 2 weeks later...
On 3/4/2020 at 11:16 PM, tshock250 said:
Pretty sure the 250 mono engine was based on the yz490?
The size and weight of the crank would make one think so... the term bulletproof is a perfect fit for the bottom end of this motor.
