nutty Posted January 26, 2006 Report Share Posted January 26, 2006 Is there good repair for the aluminium petrol tank,or can you get them welded as the seem at the bottom is leeking. Heet & petrol do not mix. yours the man in the sily hat. Help Help Quote Link to comment Share on other sites More sharing options...
mozchops Posted January 26, 2006 Report Share Posted January 26, 2006 hi mate the best thing i have found to use is araldite metal epoxy, but make sure you clean the tank with evo cleaner 191 Quote Link to comment Share on other sites More sharing options...
totalshell Posted January 26, 2006 Report Share Posted January 26, 2006 Wyldes in leeds have the white epoxy tank sealer, 20 quid, mix it up, pour it in leave for 4 days, fill it up and ride off... Quote Link to comment Share on other sites More sharing options...
cleanasawhistle Posted January 26, 2006 Report Share Posted January 26, 2006 That'll be seam, leaking, heat and silly then. Quote Link to comment Share on other sites More sharing options...
spudsdad Posted January 26, 2006 Report Share Posted January 26, 2006 dont bother, with trying epoxy repairs as they wont last long.a few months at best.take your tank to any local metal fabricators and they should be able to repair it no problem. will cost you around Quote Link to comment Share on other sites More sharing options...
dale Posted January 26, 2006 Report Share Posted January 26, 2006 Try Petseal,you might have to order it as it as a use by date,some shops do,nt keep on shelf.If you go down the welding route you might have to budget for a new tank sticker,ask first. Quote Link to comment Share on other sites More sharing options...
nutty Posted January 27, 2006 Author Report Share Posted January 27, 2006 Thankyou for your replies, tank welded all ok, yours the man in the sily hat. see you all at kilnsey on sunday Quote Link to comment Share on other sites More sharing options...
magicmat Posted January 30, 2006 Report Share Posted January 30, 2006 thing is, you have to fill the tank with water when you weld, my dad knows a guy who welded a tank without water in, and it blew up in his face, so best to fill up the water to the weld area. but job done, excellent Quote Link to comment Share on other sites More sharing options...
