brad-climber Posted March 23, 2020 Report Share Posted March 23, 2020 Hi, would anyone have or know where to locate a manual for a 280 climber? thanks Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 23, 2020 Report Share Posted March 23, 2020 1 hour ago, brad-climber said: Hi, would anyone have or know where to locate a manual for a 280 climber? thanks Have a look here https://www.motoswm.co.uk/tech/ What info do you need ? Quote Link to comment Share on other sites More sharing options...
brad-climber Posted March 28, 2020 Author Report Share Posted March 28, 2020 hi, thanks very much for the link, my problem is i fell of the bike and it went down on its side ( the rear brake side) picked the bike up and the shaft on which the gear lever sits is leaking oil out of it, the shaft had a small amount of in and out play before this happened but was fine and not leaking, i was wondering has the shaft pulled past an oil seal or has a clip jumped off, I'm hoping i don't have to split the nines just for this Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 29, 2020 Report Share Posted March 29, 2020 2 hours ago, brad-climber said: hi, thanks very much for the link, my problem is i fell of the bike and it went down on its side ( the rear brake side) picked the bike up and the shaft on which the gear lever sits is leaking oil out of it, the shaft had a small amount of in and out play before this happened but was fine and not leaking, i was wondering has the shaft pulled past an oil seal or has a clip jumped off, I'm hoping i don't have to split the nines just for this You can replace the outer seal and o ring easily, think they are all the same but best to check https://www.motoswm.co.uk/shop/swm-rotax-kickstart-clutch-cover-oil-seal-kit/ There is another o ring on the other end of the shaft, which requires casings to be split to replace. Quote Link to comment Share on other sites More sharing options...
brad-climber Posted April 3, 2020 Author Report Share Posted April 3, 2020 that's what i didn't want to hear ?, thaks very much for the info greatly appreciated Quote Link to comment Share on other sites More sharing options...
pschrauber Posted April 3, 2020 Report Share Posted April 3, 2020 If they have once got "oval" in shape which can also easely done by overthighten the kick starter screw the outer shaft is toast in terms of oil tightness or always will be incontinent. It is difficult now to source NOS replacements. Quote Link to comment Share on other sites More sharing options...
