Steering angle.
Ftwelder
The ideal footpeg position depends on a lot of things and you won't be able to know for sure until you have test ridden it so yes bolt-on adjustable position pegs are the go for an experimental bike like yours.
For a starting point, I'd mount the pegs so that the middle of the peg platform is in line with the front end of the tyre tread with the axle at mid slot.
What he said ^^  Height wise, somewhere if you take a horizontal line from the bottom of the gearbox  sprocket window.
I have noticed that people bend the down tube to change the wheelbase as well as head angle. I cut my head tube off, mitered the frame 3* steeper,  made a Bultaco head tube and am currently welding it on. I did a wheel check and have 40mm tire to frame at full compression.
Yes that will work with some frames but on many frames (eg Sherpa T and KT250) the wheel is already close to the front downtube or exhaust header with the standard setup.
