Tunney94 Posted April 3, 2020 Report Share Posted April 3, 2020 I'm thinking of having a go t my fork seals but can't find how much oil to put in. Can anyone help? Quote Link to comment Share on other sites More sharing options...
thall1 Posted April 3, 2020 Report Share Posted April 3, 2020 If you look on BetaUk website under the ‘support’ tab you can down load the manuals. My 2013/2014 bikes have an air gap of 60mm rh fork and 120mm lh fork. Slightly different than the manual but as advised by beat uk Quote Link to comment Share on other sites More sharing options...
thall1 Posted April 3, 2020 Report Share Posted April 3, 2020 Just looked in my notes... rh - 60mm air gap approx 400ml lh - 120mm air gap 350-370ml after slowly pumping the cartridge to expel the air Quote Link to comment Share on other sites More sharing options...
pindie Posted April 3, 2020 Report Share Posted April 3, 2020 I did a full strip with new seals and a mega wash out on my 2012. I have 320-330ml left in the bottle so what thall1 is saying must be about right. I used silkolene 7.5wt. Forks feel much better than they did on 5wt. I had the comp clicker on max on 5wt, now it’s nearer the middle of its range. Mine were 55mm RH, and 125mm LH. Now no leaks, lovely and plush but with control. Now I just need to find the skills to use it properly. ? Quote Link to comment Share on other sites More sharing options...
