fourex Posted April 3, 2020 Report Share Posted April 3, 2020 (edited) I have found this to fit perfectly once the locating tabs around the carb mating face are gently ground away with a dremel or similar, my pic shows after grinding/shaving. It suits a 40 mm spigot diameter which is what one wants for the 28mm Dellorto fitted to the Jumbo which has the factory fitted machined sleeve to take it from 36mm to 40mm OD, the distance from barrel to carb is spot on and 75mm between fixings. https://www.jetsrus.com/individual_parts/002_052_su.html Edited April 3, 2020 by fourex add 3rd pic 1 Quote Link to comment Share on other sites More sharing options...
