Hydramatic Posted May 3, 2020 Report Share Posted May 3, 2020 Finally got my frame on the bench today. Waiting to see if anyone can make us some rear spokes so I can get it on two wheels. Much polishing of rear rim required first though. Andy 4 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 4, 2020 Report Share Posted May 4, 2020 I made a tiny boring bar to machine the ID of the bushes with the sleeve gear in the lathe chuck, because I wasn't confident of getting the diameter right with a drill 1 Quote Link to comment Share on other sites More sharing options...
Ian T Posted May 4, 2020 Author Report Share Posted May 4, 2020 On 5/3/2020 at 7:00 PM, Hydramatic said: Finally got my frame on the bench today. Waiting to see if anyone can make us some rear spokes so I can get it on two wheels. Much polishing of rear rim required first though. Andy Expand Who did the paint? Looks like a really good finish. I think I'm going to order spokes in the next day or two. I will use the lengths from the parts book and make a little jig to put the extra bends in. It's a bit of a gamble but not sure what else to do. The other thing that I'm not sure about is the angles for the heads of the spokes. I think the inner brake side ones may be a little more than 90 degrees, maybe 100 or 110. On 5/4/2020 at 2:56 AM, feetupfun said: I made a tiny boring bar to machine the ID of the bushes with the sleeve gear in the lathe chuck, because I wasn't confident of getting the diameter right with a drill Expand Neat idea actually. Did you bore both bushes in one go? I have some adjustable reamers that should do the job. 1 Quote Link to comment Share on other sites More sharing options...
manndolins Posted May 4, 2020 Report Share Posted May 4, 2020 I'm about at same stage on frame with my M27.. If I can find time I'll start a new thread to document transition. I was lucky enough that all my rear spokes were intact and not to bent up..took some doing to get them undone without damage.. I will need new nipples..I am trying some home zinc plating on a few other parts and had a go at it on spokes ....seems to be working ok..plating 6 at a time..they won't be shiny chrome but at least clean and hopefully won"t rust right away.. 1 Quote Link to comment Share on other sites More sharing options...
Ian T Posted May 5, 2020 Author Report Share Posted May 5, 2020 On 5/4/2020 at 8:33 PM, manndolins said: I'm about at same stage on frame with my M27.. If I can find time I'll start a new thread to document transition. I was lucky enough that all my rear spokes were intact and not to bent up..took some doing to get them undone without damage.. I will need new nipples..I am trying some home zinc plating on a few other parts and had a go at it on spokes ....seems to be working ok..plating 6 at a time..they won't be shiny chrome but at least clean and hopefully won"t rust right away.. Expand Problem with the M49 is that some of the spokes are supposed to have extra bends, so it's difficult to source them. Nice work on the plating, it's something I'd like to have a go at. My dad did have a zinc plating kit but unfortunately one of the chemicals leaked and ruined it all! Quote Link to comment Share on other sites More sharing options...
manndolins Posted May 5, 2020 Report Share Posted May 5, 2020 The plating is fun to me.. I had used the caswell gold plating kits before...so I was familiar with the concept..but the zinc is cool because it's all household stuff..vinegar, epson salts, sugar..some zinc anodes..and a old phone charger (around 5 volt dc) .. the M27 has same hub as yours I believe..that extra bend is why I decided to save mine. Here's the 3 spokes on mine Quote Link to comment Share on other sites More sharing options...
Ian T Posted May 5, 2020 Author Report Share Posted May 5, 2020 On 5/5/2020 at 1:01 PM, manndolins said: the M27 has same hub as yours I believe..that extra bend is why I decided to save mine. Here's the 3 spokes on mine Expand For the older bikes I think zinc plated spokes look more 'period' anyway. I have a Greeves scrambler to rebuild and that will definitely not have stainless ones! Now that you mention it I remember that my parts book is shared with the M27. Could you do me a massive favour and measure the inside length of the longer spokes, and the total length of the middle ones in your picture? Before ordering new spokes I'm trying to get the lengths right, and not sure whether I can trust the parts book! As I cut all my spokes (stupidly!) I can't measure the lengths, but I can estimate the angles. Quote Link to comment Share on other sites More sharing options...
rcgods Posted May 5, 2020 Report Share Posted May 5, 2020 For spokes give Sids Wheels a call. He recently did the spokes for my M91 rear wheel which is spot on. Quote Link to comment Share on other sites More sharing options...
manndolins Posted May 5, 2020 Report Share Posted May 5, 2020 Here's all 3 ..just in case.. 1 Quote Link to comment Share on other sites More sharing options...
Ian T Posted May 5, 2020 Author Report Share Posted May 5, 2020 On 5/5/2020 at 5:28 PM, manndolins said: Here's all 3 ..just in case.. Expand Spot on! Thanks so much. That'll be a big help! I may give Sid's wheels a call, see how competitive they are with Central Wheel. Quote Link to comment Share on other sites More sharing options...
Hydramatic Posted May 5, 2020 Report Share Posted May 5, 2020 Ian, the paint is a Rolls-Royce colour ( not a 100% match ) done at my old place of work and yes, quite a nice finish ( I only prepped it, a pal managed to get some overspray on it whilst doing a crash repair ). I’ve not got any further with Central wheels myself as I’ve been lucky enough to be working through this dreadful time, but am following ‘spoke gate’ with interest. Andy Quote Link to comment Share on other sites More sharing options...
Hydramatic Posted May 16, 2020 Report Share Posted May 16, 2020 Having studied the pics again I’m beginning to think my tank isn’t an M49 one. It appears too narrow at the rear and doesn’t mate with the seat unit. Did I dream it or did someone on here have an M49 tank surplus to requirements ? Andy Quote Link to comment Share on other sites More sharing options...
woody Posted May 16, 2020 Report Share Posted May 16, 2020 On 5/16/2020 at 7:00 PM, Hydramatic said: Having studied the pics again I’m beginning to think my tank isn’t an M49 one. It appears too narrow at the rear and doesn’t mate with the seat unit. Did I dream it or did someone on here have an M49 tank surplus to requirements ? Andy Expand If you mean the picture on this page, the seat unit isn't located properly and is too high at the front. The flares at the back of the tank should line up to the top of the seat unit. The seat unit you have looks like a new item and they need 'dressing' in places to fit properly. It may not have the recess cut out that sits over the boss at the rear of the tank as the seat unit holds the back of the tank down. You may also have to shave a bit from the inside edge of the panel to clear the air filter hose. If you had the later bike you'd also have to remove material for clearance for the top shock mounts as they only sell one side panel for all series of M49 Quote Link to comment Share on other sites More sharing options...
Hydramatic Posted May 17, 2020 Report Share Posted May 17, 2020 You’re absolutely right Woody, I just put the tank and seat unit on for a bit of a morale boost-I knew the seat unit needed a bit of work but it needs more than I thought. Don’t think my tank will be any good without substantial work. But that can wait for a bit. Andy Quote Link to comment Share on other sites More sharing options...
Hydramatic Posted July 4, 2020 Report Share Posted July 4, 2020 Hi all, quick update regarding the M49 rear spoke conundrum. Just had my wheels built by Willis wheels at North Weald in Essex. Using Inmotion front spokes. Willis made the rear spokes and built both wheels and fitted supplied tyres. Great service and a nice job with a quick turnaround. Plus Chris Willis is a really nice guy. Andy. 1 Quote Link to comment Share on other sites More sharing options...
