brownie001 Posted April 25, 2020 Report Share Posted April 25, 2020 The open spring side of the seal faces inward (the cranckcase). If the seals are fitted correctly, there could be a gasket problem, a crack in the case or the 'O' ring/s under the crankcase nuts and bolts are shot. Not at all easy to diagnose from a description. I'd go for a full stripdown. All of the parts are available. Quote Link to comment Share on other sites More sharing options...
