4RT Tech Fork Adjustment / Settings
OregonComrade
Stupid question - think.  I have a 260 so the lower spec Tech forks.
The spring preload side (left side), what is the base setting?  The Manual talks about "turning" it, what direction?  I pulled up the tech docs directly from Formula and it says:
"Our advice is to start leaving the adjuster in middle position (you can reach the standard position by screwing it completely and unscrewing it 5 turns). After this, you can try to modify the preload, turning the governor one turn at a time, in way to feel every possible little change."
My hunch is CCW is less and CW is more?  Based on the paragraph above I would assume turning it CW until it stops and unscrewing it CCW by the 5 turns?
Thanks!
