Replacing lower fork clamp
smarty156
4 hours ago, section swept said:
Making wine to??
You must use some serious yeast if you need to secure the corks with a 6 tonne press. :) Your uncorking parties must be interesting.
Edited by d2w
Just sit around and wait for the corks to fly......with any luck quite a few ?on their own???
  • 2 weeks later...
Just a quick question on the lower head bearing. The original has a washer, then an O ring and then the lower head bearing. I've bought some Xiu-RDI bearings that come with a seal (kind of like a washer with a rubberised lip). Question is - does the new bearing and seal mean I no longer need the separate washer and o ring? There's nowhere for the O ring to seat so seems fairly obvious it no longer needs that but what about the washer?
Here's a link:
https://www.splatshop.co.uk/xiu-rdi-sealed-steering-head-bearings-32004.html
Those bearings with a provided seal look interesting. I have no experience with them, but I'd venture that you're correct and that the o-ring isn't applicable as the space the o-ring used to engage is now covered by the seal. As for the washer, it *may* be necessary if you find that if you were to use only the seal you "run out" of thread when tightening the stem nut when tensioning the bearings. If the seal and the original washer are the same thickness then I'd think you're good to go.
  • 1 month later...
So it seems you do need the washer still. In fact, there were 2 washers on there originally, despite the parts diagram only showing 1. I think it needs both.
So, I'll hopefully have that sorted later and can put it all back together. Any tips for replacing everything (both yokes, forks etc). When I took it all apart I removed front wheel and forks first, then undid the top nut and removed yokes. I was thinking I'd need to put the bottom yoke on and do that up with the lock nut then put the top yoke on and do the top nut up gently, then put forks and front wheel in to get it lined up and finally do up the top nut. Sound ok?
That's right.Leave the mudguard bolts loose,also the top yoke fork tube bolts and give the forks a good bounce to line things up.Then tighten the top nut a,then the fork tube bolts a little at a time so you don't crack the yoke,then the mudguard.Youll find that tightening the top nut slightly tightens the bearings,you might have to slacken the bearing nut to get the bars to turn freely.Probably have to adjust them again once you've done a trial and they've bedded in.If you drill and tap the head tube to take a grease nipple you can force out any water that gets in,the bearings won't need stripping out ever again
Cheers.
I replaced the bearings because the fork yoke was cracked. I'm going to be doing them up carefully! What's the torque setting for the yoke bolts?
12 hours ago, smarty156 said:
Cheers.
9nm.if your torque wrench goes that low.I suspect they got cracked by the previous owner not tightening the bolts equally a little bit at a time
  • 3 weeks later...
