mcman56 Posted April 18, 2020 Report Share Posted April 18, 2020 I have a 2001 Rev3 that is a little sharp off idle so I would like to try a weight. I have one for a 2008 but it is a different size. I can make one. Does anyone have any details like diameter, thickness weight or even a picture. I find nothing on line. Quote Link to comment Share on other sites More sharing options...
markparrish Posted April 18, 2020 Report Share Posted April 18, 2020 I can't find a picture but I put my weight back on my Rev3 when I had it and remember it being about 5-6mm thick. From memory It was virtually the same diameter as the flywheel but had an "extended chamfer" which was from about 3mm thick at the edge rising to full thickness about 20mm from the edge. I think the main issue is making sure it doesn't foul the inside of the cover - you have to add a "spacer" which is an extra plastic lip, to move the cover out a bit. Quote Link to comment Share on other sites More sharing options...
