Limmy01 Posted April 21, 2020 Report Share Posted April 21, 2020 Having a nightmare putting the front end back together, it's like an episode of krypton factor.. What order does it go together out of the radiator, exhaust and engine-radiator-engine guard brackets.. All bits in the picture.. Kind rgds Jamie Quote Link to comment Share on other sites More sharing options...
markparrish Posted April 21, 2020 Report Share Posted April 21, 2020 I'm going to say...exhaust goes on last. I think radiator second, frame first. Quote Link to comment Share on other sites More sharing options...
Limmy01 Posted April 21, 2020 Author Report Share Posted April 21, 2020 26 minutes ago, markparrish said: I'm going to say...exhaust goes on last. I think radiator second, frame first. Going to try that, t's about the only way I haven't tried Cheers Jamie 1 Quote Link to comment Share on other sites More sharing options...
stu109 Posted April 21, 2020 Report Share Posted April 21, 2020 Hi You may find that, with the bash plate attached, you can't correctly align the bolts at the top of the frame sides. If so detach front of bash plate and reattach once the frame sides are in place. You may find you need to apply some upwards force to the plate to get the bolts to align correctly. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
mcman56 Posted April 21, 2020 Report Share Posted April 21, 2020 "some upwards force" Could be an understatement if the bash plate is deformed much. If you have a hydraulic press, you can straighten some before installation. Quote Link to comment Share on other sites More sharing options...
Limmy01 Posted April 21, 2020 Author Report Share Posted April 21, 2020 Bash plate was a bitch but shes on now, now for the radiator 1 Quote Link to comment Share on other sites More sharing options...
Limmy01 Posted April 21, 2020 Author Report Share Posted April 21, 2020 All done, many thanks 1 Quote Link to comment Share on other sites More sharing options...
markparrish Posted April 21, 2020 Report Share Posted April 21, 2020 well done! Quote Link to comment Share on other sites More sharing options...
