Trials bike lockdown
mrorange
For long term storage there is fogging oil.You pull off the intake boot and spray into motor while running. Coats the internals to keep things from rusting in there.Ussaully requires a new spark plug upon start up.In the great white north here we use it on the boat motors and such that are stored for winter.Good to replace tranny or engine oil for storage also as oil gets a little acid build up in it from use.Mainly in 4t,s because of slight engine blow by.Stabil in fuel,run and fog the drain fuel tank.I spray my bikes down with a metal storage oil (except brakes of course )to fight rusting as my shop gets heated off and on which creates moisture from my propane burner.
