austin6728 Posted April 26, 2020 Report Share Posted April 26, 2020 the nephews both have Beta Evo 125's 2015 models one of them seems to be lacking in power compared to the other one and also sounding a little tinny i'm thinking new piston rings and top end bearing would help any advice would be much appreciated Quote Link to comment Share on other sites More sharing options...
dabor2 Posted April 26, 2020 Report Share Posted April 26, 2020 A couple of days ago I found a video on YouTube covering the same thing. (The things you have to do on lockdown!) Search for "This Old Tony" its title is Top End Rebuild (2 Stroke) Its quite informative and certainly humorous. 1 2 Quote Link to comment Share on other sites More sharing options...
pindie Posted April 27, 2020 Report Share Posted April 27, 2020 If it is sounding tinny, maybe it is running a leaner setting in the carb? It might be worth checking what’s in each carb before opening up the motor? Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted April 27, 2020 Report Share Posted April 27, 2020 Possibly in need of a silencer repack. Tinny sound and deterioration in response can result from original packing being clogged/burnt away. Quote Link to comment Share on other sites More sharing options...
austin6728 Posted April 29, 2020 Author Report Share Posted April 29, 2020 (edited) Ive repacked the silencer end and it's slightly better but i'm guessing there is packing in the mid section which isn't so easy to do as it needs cut open re packed and re welded. Also tonight i looked at the cab settings online and noted that the air screw setting is 1 +1/2 out from closed I'm sure when i cleaned it out the other week there for the nephew it was 3 turns out ! Guessing he's been possible fiddling around with it although he would deny it ?? will check tomorrow hopefully it's that simple don't want to get into packing the mid box if i can help it Edited April 29, 2020 by austin6728 Quote Link to comment Share on other sites More sharing options...
