mick annick Posted May 20, 2020 Report Share Posted May 20, 2020 OK, have crawled over the (earth) floor of the workshop and found the ball bearing, normal service has been restored. Thanks for all the help folks! 1 Quote Link to comment Share on other sites More sharing options...
TomL Posted July 2, 2023 Report Share Posted July 2, 2023 On 5/19/2020 at 8:04 PM, bullylover said: There is a ball bearing in between the pushrod and the mushroom shaft on the clutch end. It is around the same size as the pushrod. Any pushbike shop should have one but you may have to buy a few to make it worth their while. Graham. How do i know if there is ball bearing in their or not? When i remove the rod, there is no bearing on the end of the road? But how do i know its not in the cavity just sitting there? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 2, 2023 Report Share Posted July 2, 2023 (edited) 2 hours ago, TomL said: How do i know if there is ball bearing in their or not? When i remove the rod, there is no bearing on the end of the road? But how do i know its not in the cavity just sitting there? Lean the bike over and if there's a ball it will probably slide out. If it doesn't come out using gravity, take the clutch pressure plate off, remove the mushroom and push the ball out from either end. Edited July 2, 2023 by feetupfun 2 Quote Link to comment Share on other sites More sharing options...
lemur Posted July 2, 2023 Report Share Posted July 2, 2023 9 hours ago, TomL said: How do i know if there is ball bearing in their or not? When i remove the rod, there is no bearing on the end of the road? But how do i know its not in the cavity just sitting there? First the rod will be too short by the diameter of the ballbearing that was suppose to be in there and second; the ballbearing is in there to isolate the spinning parts from the non-spinning part (the actuator rod) so if you left the bearing out, first hint would be not enough adjustment and if you worked past that issue, the next problem will be the rod will want to spin when pressure is applied to the actuator. If the ball bearing doesn't fall out using gravity try a magnet. Quote Link to comment Share on other sites More sharing options...
