Teaboy Posted May 5, 2020 Report Share Posted May 5, 2020 I am trying to find out what is the spoke off set to the rear of an 81 248 cota. I have sent the wheels off my 248 to be rebuilt, before sending off to the wheel builder I decided to strip them myself so I could polish the rims and hubs. This has proved to be a bit of a possible oversight as the first question I am asked is do I know what the offset is, he has looked a various sites with out success. Any help would be most helpful. Quote Link to comment Share on other sites More sharing options...
rotors7 Posted May 6, 2020 Report Share Posted May 6, 2020 What about mounting the hubs then use a plumb line from the centre of the rear frame, a bit of careful measuring should give you the required numbers. 1 Quote Link to comment Share on other sites More sharing options...
dr nosh Posted May 10, 2020 Report Share Posted May 10, 2020 You are in luck. I am currently building a 1981 248 - Red frame, white tank cover over alloy tank. I have dug out the drawing and dimensions that I measured before building my wheels up. Hold fire and I will post them up. Quote Link to comment Share on other sites More sharing options...
