Ian T Posted May 10, 2020 Report Share Posted May 10, 2020 In my model 49 parts book beside the front wheel spokes it has written in pen, probably by my dad: "use 86-04-003/5" I think this might be because the rim he was using had a different ERD (effective rim diameter) to the standard one. Does anybody happen to know (or can look up) the spec for these part numbers. It should be spokes, and presumably there are two different angles for the inside and outside spokes. Thanks! Quote Link to comment Share on other sites More sharing options...
Ian T Posted May 10, 2020 Author Report Share Posted May 10, 2020 Hi lorenzo, thanks for the quick reply. Oddly this is for the front wheel - maybe the rear Pursang spokes on the larger size fit my full-width front hub too. Quote Link to comment Share on other sites More sharing options...
lorenzo Posted May 10, 2020 Report Share Posted May 10, 2020 Ian - I'm guessing here......... Front spoke part no. 86.004-003-5 appears to be one of three different spokes - with a conical hub on a Mk. V Pursang. Model 49 with parallel hub - all 36 spokes are identical. Quote Link to comment Share on other sites More sharing options...
mrb505 Posted May 11, 2020 Report Share Posted May 11, 2020 They are both 3.6x230mm although the head or and the angle may be different, you’d think the part number would the same if there wasn’t any difference. That 86 number is the part number for m91/92 front inner spoke as well. 1 Quote Link to comment Share on other sites More sharing options...
Ian T Posted May 11, 2020 Author Report Share Posted May 11, 2020 Ok thanks to you both, much appreciated. The length is the same as the M49 spec ones then. I have the remains of the spokes I cut off (in another thread on here I cursed myself for not keeping any samples, lesson learnt...) so I can measure the angles. Quote Link to comment Share on other sites More sharing options...
