al_orange Posted May 20, 2020 Report Share Posted May 20, 2020 Sorry.. just a quick one. To remove the rear wheel bearings, it looks like I need to put a socket inside the bearing and knock the opposite bearing out using the spacer. Would that be right? Doesn't look like enough clearance to knock the space aside to access the bearing directly. Also, on reassembly, does the spacer line up perfectly or does it need to be tapped into place? On mine it looks like a perfect alignment which makes me think it should go back to that position quite easily. Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 20, 2020 Report Share Posted May 20, 2020 Any hub I've ever changed bearings requires taping the bearing out from the opposite side, having first delicately leavered the central spacer to one side to give access. Quote Link to comment Share on other sites More sharing options...
huski Posted May 20, 2020 Report Share Posted May 20, 2020 I've ground down the O/D of a socket to a sliding fit in the bearing.I warm up the hub with a heat gun and tap the end of the spacer,,the bearing comes out easily?The spacer locates in the bearing about 1 mm so you can't lever it aside.Alternatively get a suitably sized Rawlbolt and tighten it into the bearing and knock it out from the other side 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 20, 2020 Report Share Posted May 20, 2020 21 minutes ago, huski said: I've ground down the O/D of a socket to a sliding fit in the bearing.I warm up the hub with a heat gun and tap the end of the spacer,,the bearing comes out easily?The spacer locates in the bearing about 1 mm so you can't lever it aside.Alternatively get a suitably sized Rawlbolt and tighten it into the bearing and knock it out from the other side New one to me, so the diameter of the axle must be smaller than the bearing if the spacer locates 1mm into it ? 1 Quote Link to comment Share on other sites More sharing options...
al_orange Posted May 20, 2020 Author Report Share Posted May 20, 2020 1 hour ago, b40rt said: Any hub I've ever changed bearings requires taping the bearing out from the opposite side, having first delicately leavered the central spacer to one side to give access. Yep, me too. Which is why I asked. This setup looks a little different. 1 hour ago, huski said: I've ground down the O/D of a socket to a sliding fit in the bearing.I warm up the hub with a heat gun and tap the end of the spacer,,the bearing comes out easily?The spacer locates in the bearing about 1 mm so you can't lever it aside.Alternatively get a suitably sized Rawlbolt and tighten it into the bearing and knock it out from the other side Ah, cool. Thanks. This is what I had assumed by looking at it but thought it best to check before I started smacking away. Quote Link to comment Share on other sites More sharing options...
gasserguy Posted May 20, 2020 Report Share Posted May 20, 2020 Get yourself a good wheel bearing remover like a Motion Pro. Saves ages and no damage to the centre shaft. https://www.ebay.co.uk/i/142889194616?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=142889194616&targetid=878634471058&device=c&mktype=pla&googleloc=9045600&poi=&campaignid=9441122835&mkgroupid=97540788884&rlsatarget=aud-629407027825:pla-878634471058&abcId=1140496&merchantid=7282684&gclid=CjwKCAjwqpP2BRBTEiwAfpiD-0E-AnYMcKbSKBN5yXD7PigVloq5PSoKDC3SN3qaMBBorHgjzG24HRoCuNAQAvD_BwE 1 Quote Link to comment Share on other sites More sharing options...
cascao Posted May 20, 2020 Report Share Posted May 20, 2020 Jitsie sell one dedicated for removing and installing trials wheel bearings Quote Link to comment Share on other sites More sharing options...
huski Posted May 21, 2020 Report Share Posted May 21, 2020 11 hours ago, al_orange said: Yep, me too. Which is why I asked. This setup looks a little different. Ah, cool. Thanks. This is what I had assumed by looking at it but thought it best to check before I started smacking away. Don't think I explained this properly.Theres a radiused edge on the inner race of the bearing and the spacer locates on this,my guesstimate of 1mm is too much.You can move this spacer over just enough for the socket to access it.As others have suggested a proper bearing remover is best Quote Link to comment Share on other sites More sharing options...
freelander andy Posted May 21, 2020 Report Share Posted May 21, 2020 17 hours ago, al_orange said: Sorry.. just a quick one. To remove the rear wheel bearings, it looks like I need to put a socket inside the bearing and knock the opposite bearing out using the spacer. Would that be right? Doesn't look like enough clearance to knock the space aside to access the bearing directly. Also, on reassembly, does the spacer line up perfectly or does it need to be tapped into place? On mine it looks like a perfect alignment which makes me think it should go back to that position quite easily. I had the with my honda xl I had hell of a job the spacer would not move to one side so I used my cheap blind bush puller it done the job if you not got them you could wield a lump then you get a long punch knock it from the other side that would been my next move if the bush puller did not work Quote Link to comment Share on other sites More sharing options...
baldilocks Posted May 21, 2020 Report Share Posted May 21, 2020 15 hours ago, b40rt said: New one to me, so the diameter of the axle must be smaller than the bearing if the spacer locates 1mm into it ? Yes it is but remember on modern bikes the wheel spacers fit inside the bearing then the spindle fits in the spacer. So with the outside spacer removed you can use the lip on the internal spacer between the bearings to knock the opposite bearing out. It's either a 14 or 15mm socket I use. This is a great system if you have to remove a wheel at a trial as the spacers stay in the wheel rather than rolling down the hill. 1 1 Quote Link to comment Share on other sites More sharing options...
al_orange Posted May 28, 2020 Author Report Share Posted May 28, 2020 So yeah, that was mega easy. Well done TRS! Heat up hub, 14mm socket on the spacer tube to knock out one side, then whatever you want to knock out the other. Clean everything up nice and tidy. Add extra grease to bearings, freeze for a bit, use suitable size socket (mine exactly matched the 42mm outer race), tap one side in. Drop the spacer in (it locates in the inner race), tap the other bearing in and double check spacer is located in both bearings before seating fully. Job done. Probably the hardest bit is getting the wheel back in the swing arm. Shame that the wheels don't have proper seals and spacers as they would seriously prolong the life of the bearings but then there probably isn't room to fit them in. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted May 28, 2020 Report Share Posted May 28, 2020 It's not really well done TRS, most modern bikes are the same set up. Certainly Gas Gas have been for years. Quote Link to comment Share on other sites More sharing options...
cascao Posted May 29, 2020 Report Share Posted May 29, 2020 If you plan to ride for more a couple of years at least, it is a good investment buy right tools 1 Quote Link to comment Share on other sites More sharing options...
jimmyl Posted May 30, 2020 Report Share Posted May 30, 2020 Special tool and a big oversize lump hammer ?? made similar but have a collar that slides on for install . makes job dead easy Quote Link to comment Share on other sites More sharing options...
al_orange Posted May 30, 2020 Author Report Share Posted May 30, 2020 (edited) 14 hours ago, cascao said: If you plan to ride for more a couple of years at least, it is a good investment buy right tools Not sure there is anything there that is more effective than the correct size sockets, like I used. If it was a tenner then I might be tempted I guess. Don't intend on changing bearings too often. Will keep on top of the greasing now I know how exposed they are. Over 200 hours of muddy and nasty enduro riding and I've changed one wheel bearing. So was expecting to get more than 30 hours out of a set! When I popped the bearing seal to check the grease, the bearing was literally packed with dried mud! Edited May 30, 2020 by al_orange Quote Link to comment Share on other sites More sharing options...
