Splitting Villiers Crank
Wessex100
Good Day,
Just starting a Villiers 6e 197cc rebuild.
I haven't done bottom end on a Villiers before. Can anyone throw some light on separating crank? Will I need the services of an engine specialist?
Will probably have more questions as the project advances.
Thanks in advance.
It is possible to get them apart, but they are tight - you won't do it in a vice. I've used a hydraulic puller to push the big end out, seemed to work fine. Re-assembly is not too bad but lining up the crank wheels to get everything running true can be trying. Obviously Villiers Services will do this for you and before Covid-19 you could take it to them and wait for it to be done.
I have only ever taken a BSA C15 crank apart, to install a new bearing.   I entrusted the work to a local heavy engineering company.  I got the flywheels back, installed them in the crankcases, and they were as stiff as ever.   Took it all apart again and had the engineering company re-true them, as they said they were 5 thou out.   They need to be way under 1/2 thou, only possible with precision measurements.
If you have access to a hydraulic press rated at 10 tons you might be able to press out the crank pin, but it may need a press rated higher. I use a 40 ton press and it can struggle on some cranks, there are some so people that have wrecked their presses before now. Then you will need a surface table and vee blocks along with at least two dti’s and stands. As teamferret suggests, use Villiers services as they know these cranks well. Unless modified your crank will be of the bob-weight type and not full circle.
way under 1/2 thou,
Really?
If you've got everything to within half a thou i reckon you've done pretty well, deserve a pat on the back, and the beers on me down the pub.
A thou is perfectly acceptable, obviously half a thou is better, way under - nigh on impossible.
