Gas gas txt clutch steel
goreboy
Hi guys,
anyone know where to get a 1.8mm steel clutch plate  for gas gas 250 txt 2014.
I can only find 2mm or 1.6mm and I could do with something in between.
any help appreciated
cheers,
Gareth
On 5/29/2020 at 7:34 PM, goreboy said:
Hi , are you in the UK?
cheers
Nuh sorry mate Australia. But just to give you a heads up you can get Gasser steels in 1.3mm, 1.4mm, 1.5mm, 1.6mm, 1.75mm and 2mm. You should be able to find a UK supplier if necessary.
