rileys Posted May 28, 2020 Report Share Posted May 28, 2020 Just bought a electronic ignition for one of my bikes and a kill switch from in motion 2 wires on the kill switch black with white stripe. And black with yellow stripe. Should it be black yellow earthed to frame ? Greg Quote Link to comment Share on other sites More sharing options...
nh014 Posted May 29, 2020 Report Share Posted May 29, 2020 It makes no difference which wire goes to ground. Connect one wire to the coil lead and the other to ground. All the kill switch does is complete the circuit to ground when depressed. 1 Quote Link to comment Share on other sites More sharing options...
rileys Posted May 29, 2020 Author Report Share Posted May 29, 2020 On 5/29/2020 at 1:46 AM, nh014 said: It makes no difference which wire goes to ground. Connect one wire to the coil lead and the other to ground. All the kill switch does is complete the circuit to ground when depressed. Expand Thank you. For the reply much appreciated put the new in motion electronic ignition in this morning got spark and fuel but no start. ? just thinking I don’t need A condenser with the new set Do I will try again tomorrow. Got to ride my bike this summer Quote Link to comment Share on other sites More sharing options...
