lotus54 Posted May 30, 2020 Report Share Posted May 30, 2020 Well I finally got around to making up a spare diagnostics cable. I have BTWICE one, but got the USB TTL interface a couple of years ago to make some more. I used another user here (darn if I can remember name right now) for the TX/RX and ground pins (already knew power from battery ones). Worked great! I tested my BTWICE first, then the one I made. I had to pick a different COM port that matched to the new cable I made, but the driver I had worked great. I see where you can download drivers for the USB interface I used also. I was running under Win7, reset the TPS and a few other tests. I did not try loading new maps with it though- but I expect it will work just fine. 1 Quote Link to comment Share on other sites More sharing options...
tjums Posted May 30, 2020 Report Share Posted May 30, 2020 Do you know if It it possible to buy the cable anywhere. I'm interested in acquiring one. ? Regards Thomas Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 30, 2020 Author Report Share Posted May 30, 2020 2 hours ago, tjums said: Do you know if It it possible to buy the cable anywhere. I'm interested in acquiring one. ? Regards Thomas Do you mean a completed cable? Or just the parts to build one. I got the USB TTL interface cable from Elmwood electronics, but I’m sure they are available in Europe. Quote Link to comment Share on other sites More sharing options...
Simonelongus Posted June 5, 2020 Report Share Posted June 5, 2020 Congratulations as always Lotus! Quote Link to comment Share on other sites More sharing options...
