s3 head inserts?
Speed Metal Army
Well as long as you are NOT talking about the 18 Gold models (because they shipped with completely different heads on them with Higher compression than the other models),
then I can tell you that red anodized insert is HIGHER compression silver is MEDIUM (STOCK) and GOLD is LOWER compression.  You can get them from TRS dealer, they are not that expensive.
